Jpflex
Electrician big leagues
 - Victorville
 - Electrician commercial and residential
I've wondered about this code before and it may also appear to be a catch 22 because codes may conflict here.
For example conduit is required to run along its supporting surface and be supported and secured within so many feet. However, if you were to use wet listed self tappers (with rubber gasket) and hole straps to the metal roof directly you would violate this code. You would meet the securing and support code while failing the 300.4E
Perhaps placing unistruts between the corrugated roof and conduit may help with this but should holes really be made in corrugated roof?
