Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Regarding the code of the day, the NEC book to my knowledge failed to address calculations for max conduit fill when nm cable is ran inside conduit. Obviously the nm cable sheathing takes up more space than the insulated conductors and shouldn't be calculated with only conductor diameter as typical.
However one book I came across said to measure the diameter of the nm cable jacket sheath and treat this as one conductor (percent fill table) when determining max conduit fill for nm cables. Is this correct?
