SiddMartin
- PA
Off the cuff, I'm pretty sure there is a code that says you have to keep the ungrounded and grounded in the same cable. Am I wrong in this? Is there an exception for a switch loop?
I was asked to run 2 wire between recepts, and ofcourse they would like the recepts switched now and want to know if I could just run another 2 wire and use 1 wire for the switched recept and not use the other wire. I dont believe I can, and would rather just rip out the 14/2 and put in 14/3 as a better install.
thanks!
thanks!
