Re: Code question-feed through receptacles
Have you ever really thought about the concept of quickwire (speedwire/backwire/backstab)? It relies on a spring. Springs move. Also, the wire is round. The spring is flat. Best case there is only a couple of molecules of contact between the round wire and the flat spring. The spring and the wire are usually dis-similar metals. They are not to far away from each other on the metallurgy scale but they are not identical (the wire is copper, and the spring is clad with some silver colored alloy). My point is the surface area of the spring to wire contact is very minimal. I could not be any worse. The spring is not even cut on a bias to maximize it's surface area contact with the wire-- the spring is cut at 90 degrees, while the spring to wire contact is more like 60 degrees. So just the sharp edge of the spring is contacting less than one degree of the circumference of the wire. The connection is subject to heat, cool, energized, unenergized, expansion and contraction forces. Oh, and let's not forget oxidation, corrosion, and arcing.
Even wire nuts rely on a certain amount of surface area for contact.
We have gone from soldering and/or screws to and/or wire nuts and finally to a little-itty-bitty-springy-thingy.
What a crappy system!
End of rant.
ieSpell caught six spelling errors in this post before I submitted it. I own the grammar and there is no grammar utility that I know of for forum text box posts and replies. Sorry! ]
