code question
Is there any requirement in the NEC requiring romex connectors to have bushing caps????? :confused:
I can't find any, but Others have insisted that it is a requirement.
G
Guest
Guest
Re: code question
BX and Flex connectors need plastic anti-short protection. Are you talking about plastic screw-on threaded bushings?
BX or Flex Anti-Short bushing:
Plastic Conduit Bushing:
Metal Conduit bushing w/ ground lug:
roger
Fl
Retired Electrician
Re: code question
Awwt, AC cable is the only cable assembly that requires "anti short bushings", (320.40) MC (330.40) and FMC (348.42) do not require anti short bushings, bushings, or insulated throat connectors if using conductors smaller than #4
Roger
A
a.wayne3@verizon.net
Guest
Re: code question
The only requirement the NEC says is that nm be secured with an approved connector either built in the enclosure or a fitting attached.
