Peter Frampton
New member
Can anyone tell me where in the national electrical code, building code or OSHA, where it states that a building has to be dried in before an electrical rough in can be done?
Take a look in the definitions, Location, Dry. No problem roping a building not "dried in".
JMHO!
Location, Dry. A location not normally subject to dampness
or wetness. A location classified as dry may be temporarily
subject to dampness or wetness, as in the case of a
building under construction.
In general, cables with PVC insulation and jacket can withstand immersion in clean water for a short period of time without being damaged as long as the ends are not immersed. If the ends of the cable are immersed for any period of time, however, the internal paper wrapping around the bare equipment-grounding conductor will absorb and transfer the water into the cable assembly. The water may then start degrading the insulation or possibly corrode the conductors. If the cable comes into contact with contaminated water, the contaminants may also act on the insulation or conductors. Over time, failures can occur.
So you guys would install recessed cans, panels, etc in a building that isn't dried in? :grin:
I know wiring is different but just another way to look at it.
