?1 225.39d does this mean i can't run a 50 amp feed to a outbuilding?
?2 i'll be feeding 4 pieces of 3phase 240 volt equipment from a 3 phase panel through a phase converter the question is do i need to bring a neutral to the panel? this panel mainbreaker will be sized for the 240 volt equipment only.
?3 if i use indivual direct burial wire (use ) the equipment grounding conductor can be any wire type (thhn, xhhn) or does it need to be USE too.
(i know it doesn't but maybe i'm wrong)
?4 what temperature rating is URD al conductor same as USE?
just some question i have and having a hard time finding the answers in the code book
please give code numbers if you have them
