S Sparky326 Member Location Michigan Nov 15, 2019 #1 For an led retrofit of a 4’ fluorescent fixture, this is a ballast eliminating retrofit, is it required to change the fixture wire?
S Sparky326 Member Location Michigan Nov 15, 2019 #3 Then does the color of the grounded conductor not have be white grey etc.
S Sparky326 Member Location Michigan Nov 16, 2019 #4 480sparky said: Nope. Click to expand... Then does the color of the grounded conductor not have to be white or grey?
Little Bill Moderator Staff member Location Tennessee NEC:2017 Occupation Semi-Retired Electrician Nov 16, 2019 #5 Please don't start multiple threads on the same subject See here.........https://forums.mikeholt.com/forum/active-forums/lighting/2544822-retrofit-wiring
