There are a few instances where wiring something for the physically challenged can run afoul of the NEC, however. Much of that has been straightened out the last couple code cycles, however.Mr. W said:Is there any speacial code requirements for wiring for the physically challenged.
Examples please Marc.mdshunk said:There are a few instances where wiring something for the physically challenged can run afoul of the NEC, however. Much of that has been straightened out the last couple code cycles, however.
Plugmold on the front of a bath vanity was, or maybe still is, one example.chris kennedy said:Examples please Marc.
while the NEC wanted the bottom at 4' above floor, presumably so little fingers won't be tempted to root around in there.
raider1 said:I am not aware of any past or present NEC requirement for a panel to be mounted with the bottom at no less than 4'.
Chris
donselectric said:isnt it 6.6 to the center of the main sw...that would put the
bottom of the panel approx 4 ft off floor.....![]()
