C3PO said:There is nothing in the NEC that says you can not insatall a receptacle above baseboard heat, but every baseboard heat's instructions that I have ever seen say that you can not install them below a receptacle. So the only code section that I know of would be 110.3(B)
infinity said:I would add that C3PO is referring to electric heat. There is no restriction for receptacles over hydronic baseboard heating.
