Copper, no. An EGC yes. At one time you could use the grounded conductor for equipment grounding at the appliance. This is no longer permitted. Many older installations used SE-U cable. This contained two insulated conductors and one uninsulated conductor. Now you would be required to use SER cable which has 3 insulated conductors and one uninsulated conductor.
