code violation-maintenance receptacle
khokonshoma
New User
I have to feed a A/C condenser unit which is 400ft from El. Panel and also need a GFCI receptacle next to Condenser unit for maitenance. Conderser unit has a local disconnect switch.
Condenser unit is 2-pole 208V.
Question:
I plan to pull a neutral wire from same panel bus and get a phase from line side of Condenser disconnect switch and feed to GFCI receptacle. All wires will be in same conduit (between El. panel and local Dis. switch)
Is there any code violation?
I am closing this thread until the op fills out his information in his profile. Contact me and I will reopen it.
