nick@venture
New member
- waukesha
i have a split refrigerant system where the wiring installed between the outside unit and inside unit is 12 awg on a 20 amp breaker. there is a communication cable that runs with it. the unit is not running properly. the manufacturer is stating the oversized wire is causing interference and should be down sized to 16 awg. is there an allowance in the code to go with there spec vs nec? what is that reference?
