Re: code
Yes, there has to be a disconnecting means. But if you are asking if the disconnecting means has to be within residence, or whether the service panel has to have a main breaker, then the answer is no. If it is a single family dwelling, the disconnect could be on the outside wall, or wherever the meter is located. If it is an apartment building or a condo, then all the disconnects could be in one room, with each unit's panel being Main Lug Only.
So let me repeat George's question: Could you be more specific, and tell us what you are trying to find out?
