Most of the FA systems that you'll probably run into today are of the non-coded type. With the ongoing sophistication of electronic devices and communication systems, locating the area(s) that are affected by a fire or smoke condition are accomplished a lot faster than they were years ago. Depending on where you are working you may still run across coded FA systems. The basic intent of a coded system was to audibly identify what area an alarm was initiated in by sounding a coded signal over the bells (or gongs) in a building (i.e 2 - 3 - 2, 2nd floor, stair 3). Typically, a coded system would have been used for a facility like a hospital where fire brigade personnel may be working anywhere throughout the building.
If you look at the photos that Bob posted you'll notice that there was a "test key" feature built into the station. Turning the key to the "box" position and activating the station would allow the spring-wound motor to operate the station without causing an alarm. Turning the key to the "gong" position would rap the gongs one time each time you turned the key to the right. They also made "pre-signal" type manual stations whereby activating the station would only sound an alarm signal in a designated area (i.e a boiler room or mechanical space or floor). These type stations were predominantly used in situations where false alarms would probably cause panic and confusion if activated on a general alarm basis (i.e the Port Authority Bus Terminal in NYC during rush hour). If, after pre-signal activation, authorized personnel responding to this alarm determined that there was truly a fire or smoke condition, they could insert a general alarm key and re-activate the station.
Many of today's fire alarm systems are computerized, have graphic annunciation, voice evacuation or pre-recorded messages on selected floors to organize the safe evacuation of a building.
I know this is a small overview but I hope this helps.
Phil
Gold Star Electric
New Jersey
