ivsenroute
- Florida
For any of you in municipalities that enforce the I-codes, there are plenty of instances where you need to be familiar with the requirements other than the NEC.
For instance, in PA we use the Energy I-code that has some things that are not in the NEC. Here are some examples:
*Internally illuminated exit signs shall not exceed 5 watts per side.
*ATM machines require 270W per location plus 90W for each additional ATM.
*Drive up windows at fast food restaurants require 400W per drive through.
*Sleeping units in hotels, motels, boarding houses or similar buildings shall have at least one master switch at the main entry door that controls all permanently wired luminaires and switched receptacles except those in the bathroom(s).
Thoughts.
Thoughts.
