COL-MET paint booth question
I'm looking at wiring a paint booth that was bought as a kit from COL-MET. It's a cross ventilation booth with 10 lights installed in the booth. Each light came with the kit and are installed in the shell of the booth. I have to install a control pannel that will be supplied by a 240v and 120v single phase circuit. 240v is for the 3hp ventilation fan motor. and the 120v is for the t8 lighting. It's my understanding that the inside of the booth is a Class 1, Division 2 location. There will be no wiring inside the paint booth. All of the lights have a myers hub outside the enclosure. I'm planning on installing seal off's on each one of the lights. After I leave the seal off's, can I run flex pvc conduit to junction boxes around the outside of the booth to connect the lights?
