I am upgrading an existing 150 amp service to a 200 amp service in Virginia Beach, VA. All the plumbing is plastic so there is no cold water ground. The inspector has told me that a second ground rod must be installed approximately 8' from the original one. I can't find this in the NEC. (I don't think he knows were it is)Can you tell me if this is code and if it is, what is the section so I can refer to it. I do understand that a second ground rod can't hurt, however there is an additional expense to the customer and I would like to justify it. Thanks.
