Wireworks
- Los Angeles, Ca
- Electrician
I'm installing a 320amp main service on a residential detached garage. Main house (120' away). Installing 225amp sub panel in main house. Do I need to run cold water bond from 400 amp main panel all the way to main water supply of main house ?
225 amp subpanel will be externally mounted on main house, will install ground rod for subpanel . Or can I just take coldwater bond to sub panel ?
