one thing that we have started to see more of here in new germany (I mean New Jersey) is more and more microlams (sp?) since you can't drill through these, sometimes a 5' run between lighting fixtures actually becomes a 30' run in order to go around these microlams.
other than that, if you are bidding off the cuff, you will get one of two scenerios: you either will be too high and not get the job, or you'll get the job and lose your shirt.
I would seriously take all the time you need and get a full material list together. If you are working off blue prints, this is quite simple.
Price all your material and add a little for misc. items.
then use your experience for how long each task should take (if you have been in the industry long enough to get a license, you should know how long it takes to install a receptacle and related wiring)
add up all your time, multiply by your hourly rate (which hopefully you determined already based on your costs of being in business)
add in your material
add in your markup and profit
Now, you have a price that if you win the job, you have a shot of making money at.
Any other way, you might as well use 007's number, because his guess is as good as yours.
