Dkimbro
- Clinton, nc
- Installation manager
Can someone tell me the Nec code section and if you can use tape to color code 3 phase on #12 wire in flex
There are no restrictions on how you identify ungrounded conductors of any size. However, it must be done to match the label on the panel that is required by that code section. That is, if the label specifies the use of insulation to identify the ungrounded conductors as to their phase and voltage, you can't use colored tape for that purpose unless you modify the label.Thanks, I believe 210.5 applies as I’m asking about color coding phase a,b, c #12 wires not grounded conductor , with tape, I was told #12 you had to buy color coded wire and could not use tape
