Color code
pedro1200
Ny
Why hasn’t the code established a standard for wiring circuits of different voltage aside from properly identifying and grouping if more than one nominal voltage is present? You cant re identify certain conductors under certain size but you can use for example black red blue for 277v circuits and vise versa . Whats the thought process behind this?
Say a building has 480 delta with one phase grounded and new 480 wye system added.
If you color code by voltage you'd have no way to tell them apart.
Not much of a benefit safety wise I'd rather know which system is which not what the voltage is.
Sometimes I want to use black red blue for phase order.
Other times I might want to use a group of blacks for circuit 1, a group of reds for circuit 2, etc.
Freedom makes America great.
Thats great but it didn’t really answer the question
There used to be a color code standard but was removed in the early 70s. Why? A electrician would see a red wire and assume it was 120 when it was actually 277. The CMP wants you to test and not assume.
Green was allowed as a hot conductor until the 2005 NEC
There are actually very clear rules for identifying phase conductors where more than one nominal voltage is used.
But why not submit a proposal for colors? Proposals for 29 code will be accepted late this year
If there is only one system then the color codes do not matter. In a dwelling with 120/240 you can use black, red, blue, brown, orange, yellow, purple, pink for ungrounded condcutors and white or gray as the neutral. What benefit would it be to limit the colors on that system?
Now IMO if there are two systems like 208Y/120 and 480Y/277 then there should be the typcial standard colors. The NEC requires you to designated which colors will be used with each system. For now that's the best you're going to get.
I am slightly color blind as well. Has messed me up a few times. When I was in school 53 years ago they got me a summer job wiring control panels in a shop. We used to mount all the components and then the first thing we would do is take the print and wire all the neutrals.
They had me work with an old timer for a week or two and then turned me loose to wire my first panel on my own. So I got started and was pretty proud of the way it was going got the neutrals done and started on the other circuits. I was about 90% done when the boss stopped by to have a look.
"What's all the pink wire for"? I had mistaken light pink for white for all the neutrals. It still looked like white to me until I held a white wire next to it. I if I recall that panel went to the Cost Guard Station in Cape May NJ. Wonder if it is still in service. Probably not.
He didn't have me change the pink the panel had to get shipped.
Red & Brown can be an issue as well. Sometimes light yellow and white.
There should be but there isn’t. Technically you can use any color for 120/208 and or 277/480. Yet they have strict guidelines for colors in other scenarios. Its just not consistent imo
I worked in electrical maintenance at a textile mill many years ago, and we had every voltage and system type in existence. The place was 100 years old and had machines from all over the world. The main service was 575 volt ungrounded delta. Transformers throughout the building made 208Y/120, 240/120 delta, 480Y/277, 416Y/240, 380Y/220, and on and on. They don't make enough colors to give each of those systems a unique set.
Basically grounded conductor, grounding conductor, and high leg.
Code needs less regulations, not more. We’re doing alright out here….
You can narrow the specific requirements down to the most common nominal voltage 120/208 120/240 277/480 and then have an exception for the scenario you just spoked about.But good point
