electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Ok consider your typical commercial job with EMT home runs with MWBC's branching off to MC down to receps and other outlets. Typically I would put 3 #12 full boats in a 3/4 EMT. Lets just say its standard 120/208 and the only electrical system in the building, so there is no requirement to code the phases. Or course most common is to use black red blue, phase A,B,C respectively and this is pretty much what I have always done, however I am beginning to question this. Although the colors help a bit keeping track of things during the pull, it seems pointless and a hassle otherwise. Things never work out perfect so after some balancing, changes/additions, moving things around, a few screw ups - its never perfect in the panel. How crazy do you go trying to keep black A, Red B, Blue C?
What does the group think about this idea: Use the same color for each MWBC. For example if I am pulling 3 full boats, one of the boats is all black, another is all red, and the last is all blue? Doesnt that make a lot more sense? Seems like you care more about the boat number and which conductors are in it rather than which phase a given conductor is on.
