Correct no local rules or amendment's. You might find a zealous inspector making up their own rules.So, phase A = black, B = black, C = black.
If there is no local or state code this is fine.
I don't like it, but whatever.
Eta: the aforementioned 210.5 C in the 2008 NEC requires ungrounded conductors of Branch circuits of different voltages to be identified. This is typically done in the colors I mentioned
And if you only have one system voltage anything goes. Splice your orange to your blue to your pink to your yellow. NEC compliant.
Why is this a problem?
My opinion is the best color code rule we could have would be to make every conductor black.
I'm guessing that you're kidding.
No, I'm not.
If you make any judgment about a conductor based on the color of the insulation you are putting yourself and others in danger. The idea that certain colors are reserved for certain conductors makes this worse.
Why is it that competent electricians are so afraid of inspectors?I never tamper with electrical wiring based on assumptions. I always take measurements. But where this is impractical I like to see certain consistencies from an inspector's point of view (though I'm not an inspector).
Yeah, he has a lot of time and somebody else's money to spend.When an installer that knows what they're doing follows a specific color scheme consistent through out an entire job I can glean certain information from that.
This doesn't mean he couldn't have made mistakes.
We do quite a bit of that sometimes anyway.Based on my experience, were you ever to find your dream job of all black conductors, say a couple hundred thousand square feet of it, you'd very quickly change your mind. It'd be a nightmare to trouble-shoot. You would find yourself marking the conductors.
