kris davis
- Irvine KY
I was pulling some control wires today and we generally pull 5 colors at a time and don't use brown, orange, or yellow. The supply house had some wire but didn't have enough to make all the pulls. They called back saying that they did have some b,o,y #14 I told them to send them and I could use one in some of the pulls. I know yellow in a control panel is designated powered from another source. But is there any thing wrong with pulling a brown, or orange with 5 other colors 950' for a on/off switch, motor overtemp, and a seal leak detector relay?
Also should we be using a white on the L2 of the seal leak 120v coil, or does everybody else consider it common and use the black wire?
