Buck Parrish
- NC & IN
How many people think the Combination AFCI breakers are GFCI and AFCI, together in one breaker ?
I have corrected 50 EC about that issue since Jan1,2008. I think most know the difference around here.How many people think the Combination AFCI breakers are GFCI and AFCI, together in one breaker ?
A ground fault device does not even look at a wave form. It just looks for current that is flowing where it shouldn't. However it is my opinion that the vast majority of AFCI trips are really trips initiated by the built in ground fault protection and not the fancy arc signature detection. Especially given the fact that the GFP trips at about 30mA and the device doesn't even look at the arc unless the current exceeds 5 amps.When it comes to the signature of Ground Fault vs Arc Fault in a
wave form. The difference is significant. From what I've seen, it's not
all "Smoke and Mirrors" like a lot of people think.
Yes I should have been more clear .Ground Fault senses current .
Arc Fault monitors the wave form, looking for alterations in the wave form that
are a "SIgnature"of an ARC Fault.
The actual information on the arc signature that the AFCI looks for is proprietary and different for each manufacturer. That being said, it has to see the signature for 8 half cycles out of 12 or something like that and there has to be a load of at least five amps. A hand generated arc could start and stop and not meet the required trip criteria.it's an interesting experiment.... take a load on a afci, say 10 amps or so,
and open up a wirenut, so you can draw an arc under load.... according
to the theory, the arc fault circuit interrupter should interrupt the arc....
i've been able to pull a 3/16" arc without tripping one....the only thing
i've found will reliably trip one is the little button on the idiot plug...:roll:
