mstrlucky74
- NJ
If these are fed from same panel and drawings/ specs don't indicate otherwise would you combine these two circuits in the same pipe? ANy reason why you wouldn't. What I'm getting at, is there ROT that maybe only 1P motors ckts could go in same pipe as receptacle circuits. Again feed from same panel( spec most of the time reads not to combine ckts from different panels in same raceway). Thanks.
