so i can have a fault of 600 watts and not trip the device .tom baker said:Yes down to 5 amps. The BC/feeder type was 75 amps
:roll:domnic said:so i can have a fault of 600 watts and not trip the device .
IF I DRIVE A STAPLE ON ROMEX AND HIT THE HOT WIRE AND EGC WILL THE DEVICE CLEAR THE FAULT.electricalperson said:the new combo arc faults are designed to detect the series and parallel fault. the branch/feeder arc faults detect just parallel
domnic said:IF I DRIVE A STAPLE ON ROMEX AND HIT THE HOT WIRE AND EGC WILL THE DEVICE CLEAR THE FAULT.
MOST LIKELY OPEN YES .BUT IF NOT WILL IT CLEAR .MOST LIKELY A BREAKER OF KIND WILL CLEAR THE FAULT. LAME REPLYbrantmacga said:Yeh that circuit is most likely now 'open'.
First please don't use all caps..it is harder to read and is considered to be shouting at us.domnic said:MOST LIKELY OPEN YES .BUT IF NOT WILL IT CLEAR .MOST LIKELY A BREAKER OF KIND WILL CLEAR THE FAULT. LAME REPLY
I'll second Don's opening comment: Internet bulletin board forum etiquette knows ALL CAPS as yelling. . . .domnic said:IF I DRIVE A STAPLE ON ROMEX AND HIT THE HOT WIRE AND EGC WILL THE DEVICE CLEAR THE FAULT.
