Combo Exit Light circuits
cdavisg
New member
We are currently remodeling a building into a church and are required to install some exit lights. Are these combo exit lights (exit light emergency light combination) required to be on a circuit of their own or can we tie into an existing circuit?
It is best to tie into the line side of a lighting circuit seving the area the combo lights are in. That way if the power goes off to the lighting circuit for any reason other than a total power outage to the building people can still see their way out
Not only best, but required per code.
unit equipment
unit equipment
unless there are 3 circuits serving the area...NEC 700.12(F)exception No 1
(i think)
Also don't forget about your exterior emergency lighting requirements when two or more exits are required. 1006.3 of the UBC. I'm assuming that since it's going to be a church that the occupant load will be over 50.
IBC 2009 says "Exterior egress components at other than their level of exit discharge"
