what is the thought on grounding and bonding of meter/farm panel at a home with garage. A friend was telling me in his state you dont need a disconnect on your house as long as you have a main within so many feet of the house. Don't quote me, but I think its like 30 feet. This rule doesnt apply in my state. So, if you have the first means of disconnect at the pole,and the service is within so many feet of the home, then any power going to the home or the garage would be a feeder. You bond nuet to ground at the meter and then run a feed to the home. Lets say you pull a feeder to the house with a ground and you are within the grace length. Would you still drive a ground rod at the dwelling and bring the ground all the way into the main panel? I would still think 250.52 grounding electrodes, would apply. if you got em, you use em. Same thing with the garage, if you have a panel in the garage within so many feet of the farm panel, do you drive a ground rod? I think you would and then it would bond at the panel along with the equipment ground included with the feeder. He tells me they dont drive a ground rod at the house, so it kind of has me a little confused. What do you think?
