I am trying to find some code references.
Here is the Challenge:
460 volt, 3 phase saw.
Wired with a combination starter. Fused and overloads included. Coil voltage for contactor is 120 volts. In this situation, they have suggested that you can run the two different system voltages into the enclosure. No transformer needed in the combo to create a 120 volt ckt. 480 3 phase, 3 wire for the motor, and then a 120 volt circuit for the controls. I am trying to find out if this is legal. Power is from two separate panels. To do any deenergized maintance, you need to disconnect power from two sources, ect. I am finding a lot of info in 430.74. and if you go to 300.3C it talks about the dif. voltages in the same enclosure. My experience with combo starters have been that they all have had a transformer feeding off the motor voltage with fuses wired in line. The disconnect means of the starter also disconnects the the?control circuit.
Thanks in advance!
[ June 17, 2005, 07:40 PM: Message edited by: copper123 ]
Thanks in advance!
