JoeStillman
- West Chester, PA
- Electrical PE
The energy code requires us to do our COMchecks using the maximum wattage that a fixture is labeled for, not the lamps we decide to use in them. So if a Progress 6" can is labeled for a 75W incandescent, it does no good for our COMcheck to specify a 13W LED medium base lamp. It seems to me that the energy code has made it impossible to specify 90% of the lights made in USA.
I confess that, up until now, I have pretended not to know that rule. Therefore, as penance, I shall spend the rest of my life at the sea shore, waiting for the consequences of my actions to overwhelm me with the rising tide. If you don't want to join me, maybe you can add a weasel note like this one that I'm leaving behind in my boilerplate specs;
My question is this; will we be voiding the UL listing by adding an extra little bit of vinyl tape to a luminaire?
The Energy Code requires that the maximum wattage allowed by a fixture be the wattage used for compliance calculations. The lamp wattages shown on the fixture schedule were used in the compliance calculations. When this wattage is less than the maximum wattage labeled on the fixture, install a printed label over the factory label showing the scheduled wattage instead.
