Is a sleeve required where communications cables run through a fire rated wall?
These are existing cables that run through the wall of a computer room (Article 645 room). The cables are sealed with fire rated caulk. But there isn't any sleeve or conduit stub through the wall.
We normally specify a sleeve, and that's what I normally see, but I don't know if the sleeve is required per code.
