COMMENT 11-29b 430.21<info> correlation
fmtjfw
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 11-29b. Thanks, Jim Williams
4 Comment:
Revise the text as follows:
red is deleted
430.21 General. Part II specifies ampacities of conductors that are capable of carrying the motor current without overheating under the conditions specified.
The provisions of Part II shall not apply to motor circuits rated over 1000 volts, nominal.
Informational Note: For over 600 1000 volts, nominal, see Part XI.
5 Statement of Problem and Substantiation.
Simple change omitted in informational note.
