fmtjfw
- Fairmont, WV, USA
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 12-93. Thanks, Jim Williams
4 Comment:
630.13 Disconnecting Means. A disconnecting means shall be provided in the supply circuit for each arc welder that is not equipped with a an integral disconnect mounted as an integral part of the welder and Each external disconnect shall be marked to identify what arc welder it disconnects.
5 Statement of Problem and Substantiation.
Text is extremely awkward.
4 Comment:
