fmtjfw
- Fairmont, WV, USA
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 13-60. Thanks, Jim Williams
4 Comment:
695.4 Continuity of Power.
(B) Connection Through Disconnecting Means and Overcurrent Device.
(3) Disconnecting Means.
(a) Features and Location ? Normal Power Source.
(2) Be lockable in the closed and open position. The provision for locking or adding a lock to the disconnecting means shall be installed on or at the switch or circuit breaker used as the disconnecting means and shall remain in place with or without the lock installed. [ROP 13?60]
5 Statement of Problem and Substantiation.
Allow the disconnecting means to be locked in the open position for servicing the motor.
4 Comment:
