fmtjfw
- Fairmont, WV, USA
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 19-43a_550.32C. Thanks, Jim Williams
4 Comment:
red means delete
550.32 Service Equipment.
( C) Rating. Mobile home service equipment shall be rated at not less than 100 amperes at 120/240 volts, and provisions shall be made for connecting a mobile home feeder assembly by a permanent wiring method. Power outlets used as mobile home service equipment shall also be permitted to contain receptacles rated up to 50 amperes with appropriate overcurrent protection. Fifty-ampere receptacles shall conform to the configuration shown in Figure 550.10(C).
Informational Note: Complete details of the 50-ampere plug and receptacle configuration can be found in ANSI/NEMA WD 6-2002 (R2008), National Electrical Manufacturers Association, Standard for Wiring Devices ? Dimensional Requirements, Figure 14-50. [ROP 19?43a]
5 Statement of Problem and Substantiation.
The complete description of the receptacle is found in 550.10(C). The informational note is not necessary.
4 Comment:
red means delete
