fmtjfw
- Fairmont, WV, USA
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 19-45_551.2. Thanks, Jim Williams
4 Comment:
red means delete
551.2 Definitions.
Dead Front (as applied to switches, circuit breakers, switchboards, and panelboards). Designed, constructed, and installed so that no current-carrying parts are normally exposed on the front. [ROP 19?45]
Disconnecting Means. The necessary equipment usually consisting of a circuit breaker or switch and fuses, and their accessories, located near the point of entrance of supply conductors in a recreational vehicle and intended to constitute the means of cutoff for the supply to that recreational vehicle.
[ROP 19?45]
5 Statement of Problem and Substantiation.
The article 100 definitions of Dead Front and Disconnecting Means serve as the definitions for these terms through the entire rest of the NEC. They appear to be sufficient for Article 551 as well.
4 Comment:
red means delete
551.2 Definitions.
[ROP 19?45]
