fmtjfw
- Fairmont, WV, USA
4 Comment:
225.52 Disconnecting Means.
(F) Identification. Where a building or structure has any combination of feeders, branch circuits, or services passing through or supplying it, a permanent plaque or directory shall be installed at each feeder and branch-circuit disconnect location that denotes all other services, feeders, or branch circuits supplying that building or structure or passing through that building or structure and the area served by each. If the building or structure is not required to have disconnects, the permanent plaque or directory as required above shall be installed at each point the circuits passing through enter.
5 Statement of Problem and Substantiation.
Let us start with the purpose of 225.51(F). I believe it is to protect electricians working on circuits in the building or structure and to protect firemen in the case they need to enter the building under emergency conditions.
The most extreme case is a building or structure that has no electrical equipment but has circuits feeding through it.
