COMMENT 8-157 388.120 Correlation problem
fmtjfw
I'm looking for constructive criticism on the following, and if you think it is merited, support in the form of comments from you on 08-157 388.120. Thanks, Jim Williams
4 Comment:
revise the text as follows:
388.120 Marking. Surface nonmetallic raceways that have limited smoke-producing characteristics shall be permitted to be so identified. Each length of surface nonmetallic raceways shall be clearly and durably identified as required in the first sentence of 110.21(A).
5 Statement of Problem and Substantiation.
110.21 is now devoid of text, the text is now in 110.21(A).
