I am replacing 3 prong receptacles in a commercial building that has metal conduit and metal boxes inside block walls. They were previously replaced with 3 prong receptacles with obviously no ground wire. I know the rules for residential as afar replacing ungrounded receptacles, but since the conduit was used as the EGC should I still use a GFI breaker/receptacle? Thanks
