JROD
- North Carolina
Hi All,
Most of my experience is as a residential contractor. I will be going to give an estimate on a commercial job and I would really appreciate some advice on two items:
1. The customer says that he has a 50? by 70? bay with 30? ceiling that has inadequate lighting. He says the temperature should never drop below 50 degrees inside the bay (I don?t know about that). He needs at least 15? clearance. He asked me to recommend lighting to him, cost is not as much a concern as having the light comes on fairly quickly, and good bay illumination and he wants fairly reliable bulbs that do not need to be replaced every six months.
2. He only has one receptacle in the bay, the main panel board is full, but the previous owner, according to the current guy, had some sort of ?3 phase 360 amp contraption? that the previous owner had removed at the cut off. The new owner wants me to replace the cut off with a sub panel, using the existing wire and cap off the 3rd phase at the main and the sub-panel. I haven?t been able to find anything in the code about this, but besides the code, I would like to make sure the job is done right and that it is a quality professional job. Any suggestions?
I would like to have my ducks in order before I go out to meet with him next week and be able to give him fairly educated recommendations. I have been doing research on this, but I feel that you can?t beat experience.
Thanks,
Jos?
Thanks,
Jos?
