Commercial Meter+ LC wanted
Toros
Tujunga, CA
Hi,
For 3-story apartment building,
I am looking for a Siemens commercial type meter+load center combination
rated @ 400A, 3-phase with (2) sub feed 200A disconnects
that can be installed on a wall and,
provides supply feeders to the elevator and a house panel that is for the common area ltg + power
Thank you
Any ??
Part number???
kwired
Electron manager
NE Nebraska
since you specified Siemens, you are limited to what Siemens makes, or will build for you. Building for you may come with a cost.
hbendillo
South carolina
Meter centers commonly are equipped with and incoming section that feeds through meters to disconnects all of which are contained in the integrated enclosure. I have never used or seen one myself that also has the load centers in that same enclosure. That shouldn't be problem though just install your load centers next to the meter center and feed from the disconnect.
Hi,
Thank you
Any ??
Part number???
Dont you have a supplier that has a guy that does gear you could talk to?
