Hello! I have a question: there is an apartment complex and the owner build a 50 x30 shed on the same ground and I installed a 100 amp sub panel, and outlets all around the walls.The owner said it is for maintenance personnell and to keep equipment in storage.When the inspector came he told me that i had to install gfci on the outlets for protection of personnell as stated in the code. I only argue with the inspector on the fact that the shed is not considered a residential building but a commercial one even though it is located on the same lot as the apartment complex and therefore gfci protection is not needed. Can some one help me? is gfci protection needed or not regardless of it use or setting. please name code reference when asnwering. Thank you so much. Mad Max
P.S. Apparently i posted a previous question three times earlier and cause some confusion. Sorry.
