DaveBowden
- St Petersburg FL
I'm bidding a job for a pharmceutical distributor. General offices and areas to fill orders.
The building is just over 4600 sq feet. There is one 4500W water heater, 76 receptacles, and 72 2X4 3 lamp lay-in fixtures. There are also 4 a.c. systems. They are heat pumps (4600VA per compressor) with 10kW auxilliary heat strips.
My questions are:
1. Since this is not a dwelling unit, is there any derating available for the a.c. systems due to having 4 separately controlled units?
2. Is there any derating available for the heat pump strips ( 65% af auxilliary strips with heat pumps?
The engineer and I are disagreeing over the service calculations. It is single phase.
My questions are:
