Commercial vacuum
Does a 120 volt vacuum with a 25 amp nameplate load really need an #8 thhn? If it were 24 amp nameplate #10 thhn would work? Motor load? 125%?
If you have 75 degree C terminals (if new equipment that is pretty much standard today), then 25 x 1.25= 31.25. 10 AWG, 75C conductor has an ampacity of 35.
If you must use conductors at 60C rating then yes you must use at least 8 AWG.
I think kwired picked up on your "error" but please explain why you think a 25 amp motor needs a #8 wire? And by the way, what is the horsepower rating on the nameplate? Read article 430 or Mike Holt's instructions on sizing motor feeders and you will learn why I asked this question.
My reply was based on having a FLA of 25 amps regardless of how it was determined. No more details then OP gave we don't know if 25 is the FLA or is some other value.
I knew that, I just didn't want to ask for more information from him without acknowledging that he had actually received the answer from you. :)
If the 25 amps mentioned is recommended breaker size the actual FLA may very well be low enough that 14 AWG conductors are code compliant.
