commercial vs residential
How low can you go?
How low can you go?
matt silvey said:
Is there a minimum height for a breaker box?
Yes, but it is only for a mobile home and it is two feet above finished grade or working platform to the bottom of the enclosure containing the disconnecting means. Since the service for a mobile home is outside the rule does not apply. Two feet is ridiculously low; however, you may mount a panelboard as low as you are comfortable with mounting one. :smile:
