I have a commercial job (complete rewire with exposed ceiling and wall access -wood construction, to be covered with 5/8" drywall) and the code allows me to wire it with NM cable. Just curious how many contractors out there still use metal cable and emt when they do "commercial" work. When I started doing electrical work years back, the Co. I worked for always treated commercial work differently than residential, we never pulled romex period. In the recent past I still run into local EC's who do it all in metal. The only problem I forsee is getting the home runs into the panel since it's surface mounted on a block wall and if I used a conduit stub as a sleeve it would be muchlonger than the 24" allowance and derating would play a factor. Thanks.
