i havent had much commericial exprience. i am sure you gentalmen can help. i have been asked to do an upgrade on a commericail building its is an overhead service approx. usinin 400 amps, i currenly have this to work with: the imc comes down into a 30x18x10 j box through the bottom of this j box an offset to meter face, out of the left side i have a 3.5x4 nipple to a 10x40x10 gutter out of this gutter through parrell 250 mcm thhn runs they have split bolted two 200 amp subs and also two 60 amp disconnects and a 60 amp sub panel, to feed these 60 amp dissc. and sub they used 1o thhn out of the split bolt. My problem is i cant reuse the 30x18x10 j box because it hase no cover either does the meter pack , can i use a k4ut 400 amp meter pack and run parallel 250 mcm up through the weather head w/ out havin to repace from the gutter box on?
