Alwayslearningelec
- NJ
- Estimator
So I've been told before if the schedule indicate separate 3/4"C you figure it that way. But for these I would think instead of separate pipes from the panel to each 20A load you'd run ONE pipe out of the panel to a location near the loads( they are right next to each other) then branch. Make sense? Although I guess they could hold you to running separate pipes. THoughts?
